Old 29-Aug-2016, 8:12 AM   #11
featherz
Originally Posted by Tigerbangs View Post
TWRGB poses the biggest challenge because the DB-8e is going to be completely blind to it. If you wan to get all of your networks, you will need an all-channel solution.
I am getting CBS now, although not sure how if the DB8E should not see it. Maybe it's the clip on VHF addon? I've been pointing at 203ish - we figured out that was pretty much the only decent direction. I think I should definitely add a pre-amp. We'll probably also get the antenna mounted higher.
featherz is offline   Reply With Quote
