Old 29-Aug-2016, 2:22 AM   #10
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
The NY Capital District market has 4 VHF TV stations:WRGB on low-band channel 6.WXXA on high-band channel 7, WNYT on channel 12, and WNYA on Channel 13. WRGB poses the biggest challenge because the DB-8e is going to be completely blind to it. If you wan to get all of your networks, you will need an all-channel solution.
While I understand that you are reluctant to get rid of the DB-8e, your best bet would be to get a Winegard HD-8200u antenna, mount it as high as you can on the roof, and aim it at the Helderberg Escarpment, where all the Capital District are located. The Helderberg Escarpment lies at 203 degrees south of your location, and should be a fairly easy pull from your location if the antenna is mounted and installed properly. You can add a preamplifier, like an AntennasDirect PA-18 if you want more signal strength to add additional TV sets
