Old 28-Aug-2016, 11:41 PM   #2
Welcome, pigman1965:
You have a problem location with the major networks in different directions and on different bands. You haven't told us what you hope to get, where the antenna will be mounted, how long the feed lines will be, and how many TVs.
So I will have to guess that the antenna will be outside, in the clear, with no trees or buildings in the signal path. You have entered 10 feet on your report which doesn't seem high enough, but I don't know what your location looks like.
There are several solutions, none of which is ideal.
Solution Number 1:
A MCM 30-2476 VHF antenna aimed at 212 degrees magnetic for WFXL FOX and WALB NBC/ABC.
http://www.rabbitears.info/market.ph...&callsign=walb
and an Antennas Direct DB4e aimed at 160 degrees magnetic for WSWG CBS. Combine the two antennas with a UVSJ.
http://www.solidsignal.com/pview.asp?p=uvsj
Solution Number 2:
Antennas Direct C2V with the UHF loops aimed at 160 degrees magnetic for WSWG CBS and the VHF dipole broadside (perpendicular) to 212 magnetic for WFXL and WALB. Add a Channel Master 7778 preamp.
If you must have PBS, it will get even more complicated, because then you will need three antennas with a custom combiner or an A/B switch OR an all-channel antenna and a rotator.
You might get WMUM PBS with solution Number 2, because the dipole is bi-directional for 212 and 28 degrees. And you might get WABW PBS with solution Number 1, even though the 30-2475 isn't designed to pick up real channel 6.
