Old 28-Aug-2016, 10:42 PM   #4
Then I would run a commercially terminated piece of RG6 right from the antenna to a television and make sure the problem isn't with something between the antenna and the television.
Good idea. With an installation that old, the antenna and the feed line are both suspect. You need to find out which is defective.
The trees might also be part of the problem.
