Old 28-Aug-2016, 2:52 PM   #1
kev23
Antenna suggestions for chicago.
http://www.tvfool.com/?option=com_wr...e2cb1d2c56b32f
The major Chicago TV networks that are at true 140 degrees are the most important to me including WBBM VHF Hi real channel 12 (2.1).
I would be fine with using a yagi antenna if it would work the best.
I can mount the antenna 25-30 feet up on my chimney or higher if needed, I do have a lot of trees surrounding my yard.
The cable run to the TV would only be about 10-15 feet longer than the recommended antenna height.
Any suggestions for what products would work the best for me would be appreciated.
kev23 is offline   Reply With Quote
