Old 28-Aug-2016, 12:16 AM   #7
wizwor
My house is surrounded by red pines. These trees are about 100' tall with tufts of evergreen at the top which sway in the wind and fill with ice and snow. My DB8e is in the attic pointed out through a peak into blue sky below those tufts. I do not get much value out of the articulating panels just because of the distance to broadcasters.
Do you have an pre-amp on the antenna? How many televisions do you feed? Is that signal amplified?
FWIW, this is about the worst reception you will get all year as the leaves are full of moisture and blowing about.
wizwor is offline   Reply With Quote
