Old 27-Aug-2016, 11:06 PM   #3
featherz
Originally Posted by wizwor View Post
The DB8e is a great UHF antenna. Replace your VHF retrofit with one of these pointed at 203ish to get 6, 9 (maybe from the back), 12, 7, and 13.
http://www.mcmelectronics.com/product/30-2476
If you have a phone or a GPS, run a tvfool report from the coordinates of your antenna. Run it at 15-20-25-30' agl to see if height makes much of a difference for channels you want.
Thanks! I did run another tvfool with the different heights (just from zip code) and it did not make much of a difference at all, but those tall trees could be making a huge difference here. I'll try running it from the exact coords shortly and see if I can get a better listing.
Hubby almost got seriously injured when we put the antenna up higher the last time so kinda hoping it won't help too much. :P
featherz is offline   Reply With Quote
