Old 25-Aug-2016, 9:32 PM   #17
MnToyGuy
http://www.tvfool.com/?option=com_wr...e2cbe9db254537
Finally got my data cable run hooked up temporary. I'm very impressed with the DB8e. No issues with the signal even through a 4 way splitter.
I guessed at the alignment, so I may be off by 10-15°. I get 11, 13, 31 and a very snowy 47. I'm right on the LOS height for 24/26/28. I do not get those channels. I'll be able to get another 2.5' by raising the base up to the deck. I'll do that and align, then try trimming tree branches if needed. Pictures show installation and the trees in the way. There's a hill there, which I am (hopefully) just peeking over
If that fails, I'll just align to 226° and try to pull in 15.
Now time for AM and FM setups. I have a long wire AM antenna and will be using the above mentioned FM (I need to pull in 101.3 and 103.1). Do these need to be split or is splicing acceptable?
MnToyGuy is offline   Reply With Quote
