Old 25-Aug-2016, 4:10 AM   #10
Lexpilot
Thanks for all the replies, it was worth the 5 day wait.
To be clear, the CM7777 is on my house 40 miles north of Madison not the daughters house in Milwaukee I'm working on.
The coax does go through a splitter/ grounding block. Should the FM trap go between the antenna and the splitter/ grounding block or closer to the receiver?
I've seen a piece of screen used as a reflector for the home made antennas, should it be connected to the shielding or insulated from everything.
If I give up on the coat hanger antenna which one would give best results, the C2V-CJM or the ANT751?
I'm going on Sunday to attempt the fix. I might just find that aiming it a bit differently with a reflector will help.
Thanks again guys, I post back after this weekend.
Dan
Lexpilot is offline   Reply With Quote
