Old 25-Aug-2016, 1:46 AM   #9
For the filter and attenuator to be fully effective, you might need to ground the coax shield with a grounding block connected to the house electrical system ground. Otherwise, the interference might get directly into the TV cabinet. It is not required by code, but might make a difference in performance.
Please let us know the results of your tests on this same thread.
Best regards,
rabbit
