Old 25-Aug-2016, 1:05 AM   #7
Thanks for the exact location report; the signals are slightly stronger.
The antenna I made is this one:
That antenna isn't an optimum design, but with signals that strong it has more than enough gain. Did you add a reflector to make it directional? A reflector can eliminate multipath reflections which can be a problem for an indoor or attic antenna.
Would fm interference cause the drop outs as well?
Yes; you can add an FM filter. Antennas Direct has an FM filter; you might need 2 in series.
I redid your FM report to match your new TV report; the signals are still very strong:
http://www.fmfool.com/modeling/tmp/4...e/Radar-FM.png
I have a CM 7777 at home with a switch that says FM trap that I leave in (on).
Yes, some preamps have an FM filter, but as rickbb said
Don't use the pre amp, you're already getting too much signal now.
Do they accomplish the same thing?
An FM filter makes the FM band signals weaker; an attenuator makes all signals weaker.
I take it there are no good indoor "rabbit ears" for a situation even this close to the transmitters?
Many people have had good results indoors with the Antennas Direct C2V. If you buy the BestBuy C2-V-CJM version, I think it comes with an indoor base.
https://www.antennasdirect.com/cmss_...ickStart_f.pdf
Rabbit, can you give me a link to an example of an anttenuator?
A splitter can be used as an attenuator. A 2-way splitter gives 3.5 dB attenuation; a 4-way, 7 dB. But you might need more than that. Antennas Direct makes a variable one:
There are inexpensive fixed value attenuators:
http://www.3starinc.com/drop_in-line_attenuator.html
http://mjsales.net/collections/atten...ant=1083705673
Attenuation values 1, 3, 6, 8, 10, 12, 16, 20dB (FAM)
click on 1 dB for other values; the up and down arrows are faint
The attenuator will make the TV and FM signals weaker.
