Old 24-Aug-2016, 8:53 PM   #24
Not easily done. It is usually measured on an antenna range, by noting the two azimuths where the gain is 3 dB down from the max; these two points are also called the half-power points.
Now maybe some more about overload:
WEVV has a Noise Margin of 56.8 dB. If you add the 10.5 dB gain of a Winegard HD7694P, that brings you up to 67.3 dB; that's OK.
WEVV has a signal power of -34.0 dBm = 15 dBmV
The CM7778 has a max input of 34 dBmV
WEVV 15 dBmV + 10.5 dB ant gain = 25.5 dBmV; OK
WEVV -34.0 dBm + 10.5 dB ant + preamp gain 16 dB = -7.5 dBm; close to tuner overload
ATSC Recommended Practice:
5.1 Sensitivity
5.2 Multi-Signal Overload
