Old 16-Feb-2010, 3:28 AM   #1
mikes781
Looking for Advice Selecting an Antenna
Hello,
I had been thinking about installing an antenna to supplement our cable programing with OTA HD and stumbled across this page. I ran the signal analysis and was surprised to see how many OTA digital transmission could be available in my area. Seems like most of them are clustered toghether and not too far away.
http://www.tvfool.com/?option=com_wr...27eeb5ede690e1
I did notice that most are UHF other than ABC which is VHF. I'm not sure if I would need a separate VHF antenna to receive ABC? I don't have an existing antenna on the house and I will need to run wiring. I am open to putting an antenna on the roof and would like to run three or four lines to different rooms. The area around my home is relatively flat with no buildings taller than our two story house. There are just some tall pine trees that are probably in the line of site between the house and the direction that most of the signals would be coming from. Sorry for the noob question, but will the typical TV antennas also work for FM signals?
Mike
mikes781 is offline   Reply With Quote
