Old 25-Jan-2011, 9:16 PM   #6
Dave Loudin
Dave, please take the time to look at your report, especially the Signal Analysis FAQ that's linked to near the top of your report. The answers to all your questions are there, really. What I write here assumes you've read that.
Remember that the quality factor is the NM, noise margin. Anything with NMs above 40 should easily be picked up by an indoor antenna. Note the stations at roughly 50 degrees - they all have TONS of signal strength and cover all the major and minor networks (see the netwk column?). You can easily get all of them with the M4 bowtie array design if you want to experiment. Something on the order of an RCA ANT-751 would also work well.
