I second that advice.
I have a similar report as yours and a 4 bay bow tie with no reflector aimed at your easterly stations will pick up those and the westerly ones from the back of the antenna just fine.
Barring any trees, buildings or other objects that block the signal path of course.
Adding the VHF element will pick up 11 out of Durham as well.
You have too many close strong signals to need a pre-amp. It will overload your tuner and make things worse, not better.
