You do not need any amplifier. Do NOT use one unless directed to do so.
What is the difference between the JUICE amplifier vs the PA18 amp
The PA18 is a deep fringe only model, it can not be used in any situation where there are strong signals. The Juice may be used in ANY situation where a preamp is required. There are other differences, some subtle, some not so much including a cellular filter in the Juice, but they're otherwise similar enough.
