Old 23-Aug-2016, 7:40 PM   #1
Lexpilot
What am I missing here?
http://www.tvfool.com/?option=com_wr...e2cb373daafaba
My daughter is renting a house near UW Milwaukee campus and I hung a homemade coat hanger 8 bay on a 2X4 in the attic. There are miles of coax from dish and cable from previous renters that I used some of to run down, around and back up to the opposite corner of the house.
The antenna is in the west end in a window, there are houses in line with the stations that are only a couple miles out.
She gets everything fine except the NBC station WTMJ real channel 28 VIRT 4.1.
That is the station that has Sunday night football (she's a packer fan).
This station is in line with the others and only a couple miles out.
I was under the assumption that anything over 13 real is uhf.
Why doesn't this channel come in?
The others all show nearly 100% signal but have occasional drops to 50 or less. I think the short drop outs are interference.
Is there a good portable antenna we can try at the tv? I tried a $20 RCA flat one that didn't work well enough to use.
I can run new coax across the attic and down to the tv With a 50 foot run. Is there an antenna I can put up there to give better reception?
Help me keep her off cable please!
Thanks in advance,
Dan
Lexpilot is offline   Reply With Quote
