Old 23-Aug-2016, 2:52 PM   #6
i have a cpa 19
OK, good if it is working properly.
Im using a radio shack joiner since i have a vhf and uhf antenna.
That doesn't answer my question. Some people try to use a splitter in reverse as a joiner and some people use the correct device, a UVSJ.
You didn't answer ADTech's question
3. What is out in front of the DB8, for example, trees, buildings, etc?
Assuming the path is clear in front of the DB8, you should be receiving those two channels OK. If not, something else is wrong, but we haven't discovered it yet.
