Old 25-Jan-2011, 4:49 PM   #5
You have several signals so strong that a paper clip should receive several of them. Therefore, there's probably a step that you're missing that is keeping anything from working.
Do NOT use any antenna with an amplifier. Use a passive loop & rabbit ear antenna only. If you can place it in a west or southwest-facing window, do so for best results.
Since you're using a converter box:
1) Verify that you can see the menus of the box on your TV screen first.
2) Using the converter box's remote, run a channel scan/search to see in anything is received.
Keep in mind that you might always have a defective box or antenna, so be prepared to substitute.
