Old 21-Aug-2016, 9:28 PM   #11
cflannagan
The HDB4X is good for ABC, but not optimum other 3.
You only need two antennas if you want to keep the HDB4X UHF antenna for ABC, and add a second antenna for NBC, CBS, and Fox on VHF. If you want just one antenna for all four channels, you need a UHF/VHF combo antenna like the Winegard HD7694P or the RCA ANT751. The RCA has a smaller form factor, but it doesn't have as much gain which might be needed because of the trees I see to the SE.
If I go this route - mounting a 2nd antenna - I will need to get additional mounting/mast hardware - not something I can piggyback/reuse the current mast I have now, correct? (Just making sure I understand what's involved)
Can you tell me the make, model and specs for it?
Yup - it's the same powered amplifier that came with the omnidirectional antenna, which I left in place and am using it with the HDB4X. Seems to be getting better results with it than without.
https://images-na.ssl-images-amazon....SR970,300_.jpg
Thanks for the photos. The signal strength shown for 8.1 might be misleading if the amp is needed to compensate for the VHF deficiency of the antenna.
Ah yeah - I took photo of the signal strength with powered amplifier in place.
It looks like your UHF antenna is on a satellite mount. Hopefully your installer grounded the mount and grounded the coax with a grounding block. which is important in your area with so many storms.
Yup - I'm pretty sure it is grounded. I see what seems to be ground wiring going from the coaxial (that I can trace back to the antenna/mast), and the ground wiring going down the wall, into the ground.
I will try to get the antenna you suggested and try it to see if results improve. The problem is, it seems to be huge.. 6 feet long? Which means it'll be pretty visible from street. This would likely enter the territory where HOA would start sending me letters. So I might need to ask the installers to come back and move it to back of house if needed.
cflannagan is offline   Reply With Quote
