We're talking next level, right? WMOR carries This TV which has retro programming and very good movies. WTTA carries My Network and Cozi. WTSP carries Antenna TV and Justice TV. If you are Greek, you may be interested in WZRA which would be a challenge to pull in with a single stationary antenna.
You should explore the other channels in case there is a special interest for you (heroes and icons is mine). If that channel happens to be on either flank, you will want to get an antenna with sufficient beam width to grab that station for you. H&I happens to be a sub channel of WTVT in Tampa -- which is on your list.
I think you are going to be surprised how high that next level is. Have fun!
