Old 21-Aug-2016, 2:45 AM   #13
nickgalliart
Update: Changed out the dimmer for a basic switch and still had the same problem. It turns out it was a 2 fold problem and the LED bulbs were also causing the interference even with the basic switch. I put some incandescents in and everything seems to be working pretty good. I had a few newer LED bulbs, Great Value from Walmart, and they even worked with out issue. My 3 year old Lighting Science bulbs from the Home Depot were not shielded like is required by the government now, probably why they were discontinued. I plan on replacing all the bulbs with newer LEDs.
nickgalliart is offline   Reply With Quote
