Old 18-Aug-2016, 9:58 PM   #6
ihwf_vp
As an update, I tried a few different amplifiers and I could get the signal up to a better level, nut the noise floor rose right with it. No matter what combination I tried, I always seemed to still have an SNR level around 22. If anything, I've found that going no amp at all has actually provided a little bit better quality of signal than going with an amp.
As most of you are aware, it does appear that I'm just in a Tropo zone with this. When conditions are favorable, I've had really good luck. When conditions aren't, I've seen a loss in signal and sometimes to none at all.
Are there any particular antennas that anyone is having good luck with in picking up Tropo signals from long range of around 100 miles?
ihwf_vp is offline   Reply With Quote
