Old 18-Aug-2016, 8:30 PM   #4
Hi, Angie; welcome back.
Most of your channels are UHF, but NBC is on real channel 10, so you need a VHF/UHF antenna like the Winegard HD7694P mounted outside as high as you can get it. The antenna should be aimed at about 135 degrees magnetic.
ION will require a separate Antennas Direct DB4e antenna aimed at 348 degrees magnetic and a custom combiner to add it to the other channels. Maybe you can do without ION for now.
There are trees everywhere, is there a way to obtain info so I can provide accurate details?
If you are willing to provide your exact address or coordinates in a PM I can look at the satellite view of your location.
Because of the hill in the signal path, I suggest making a test with just one TV, and then add a 4-way splitter for more TVs. If the signals are too weak, replace the splitter with a Channel Master 3414 distribution amp.
