Thread: Updated report
Old 18-Aug-2016, 12:01 AM   #9
To test the PCT amp if power is available at base for transformer:
Code:
    DB8 > 18ft coax
                 UVSJ > PCT AMP > grounding > coax > splitter
                 /           |       block
Y5-7-13 > 18ft coax          |
                         DC PWR into upper left port
                         if AC is available at base
  Use lower left port for coax to grounding block
If AC power is not available at base:
Code:
    DB8 > 18ft coax
                \                                    PCT
                UVSJ > PCT AMP > grounding > coax > power > splitter
                /                  block           inserter
Y5-7-13 > 18ft coax
