Old 15-Aug-2016, 1:30 AM   #3
Which WESH signal are you receiving, the main channel 11 signal or the channel 18 Deltona translator? Both will identify as "2.1" on-screen, you'll need to dig deeper into your menus to see if there's a diagnostic screen that provides extra info.
The problem is, when the weather is bad WESH channel 2.1 tends to break up.
The cause probably depends on the specific channel being received. Weak VHF signals are often often affected by any lightning (broadband impulse noise) anywhere in the vicinity, perhaps 20-40 miles away. Weak UHF signals dropping out during rain is most commonly caused by wet trees in the signal path. Either symptom is going to be aggravated by having placed the antenna inside an attic. The solution usually starts by putting the antenna where it can actually catch signals of better strength and quality (outside, up in the air).
