Old 13-Aug-2016, 10:57 PM   #9
Outlier
Rabbit73,
Thank you so much for your specific advice. I generated the last map by putting in just the zip code and then moving the icon to the location. The first map I generated with latitude and longitude as the street address yielded a map that was much less precise. The coordinates are 32.67420196220507,-97.48467542231083. The marker I positioned manually may have been off a little from that location but not by much.
Regardless of the precise location I'll likely need an antenna as you suggest. I'll let the forum know how it works out. Thanks again to everyone for all your help.
Outlier is offline   Reply With Quote
