Old 13-Aug-2016, 1:29 AM   #8
Thank you for the new report. It is close to your first report; I see Rio Frio Trail and the creek again. You haven't given us the coordinates for the latest report, so I think I will stick with the first one I did based on your original coordinates, unless you want to give me the latest coordinates in a PM.
http://www.tvfool.com/?option=com_wr...e2cba0a97b9441
Because of your uneven terrain, the channels listed are in a different order from report to report.
Can the signal make it over the hill?
My answer remains the same: you have a good chance of receiving some channels if you can get your antenna high enough.
You will need a combo antenna aimed at 102 degrees magnetic for VHF-High and UHF because ABC is on real channel 8. I doubt that you need a VHF-Low antenna for channel 6 because KBFW is an FM station disguised as a TV station. You can listen to it on 87.7 FM. KSFW is infomercials.
If you can get it high enough a Winegard HD7694P might work; the bigger HD7698P has more gain. Tilting them would be a DIY modification. Try it without a preamp first. If you have more than one TV you might need a distribution amplifier. A last resort would be a preamp instead of the distribution amp.
A alternative would be separate UHF and VHF antennas that have a tilt feature built in, like the Antennas Direct 91XG and the MCM 30-2475.
What antenna are you using now?
