Old 10-Aug-2016, 6:50 PM   #26
rickbb
Originally Posted by Sev View Post
I might have to get creative.
That darn channel 5 is going to be the fly in the ointment.
I need to boost 39.1 which is 614-620 Mhz. The transmitter is mounted lower than the rest of the local transmitters and since everything is already edge 2 it def isnt helpful.
Aside from 39.1,2 I do however get 100% signal on all the local channels.
If you only want one channel you can get a band pass filter from Tin Lee that will block that channel from one antenna and allow only that one on the other. BUT, $$$$$$.
