Old 9-Aug-2016, 1:16 PM   #22
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Path to Rockford with Antennas 300' AGL
Good morning do you receive Rockford at all ,and if you do what is the height of your antenna set-up now, and go back to the tv fool REPORT ,and put it the new hight firest be for doing it and see what happens but like they say about the higher you go with an antenna, the better the antenna receives,and what are you using for a amp
Good Morning.
All your questions were actually addressed in the post just before your questions.
Currently 57 feet AGL, Rockford doesn't have a direct path.
If I put in a theoretical height of 300':
Last edited by bobsgarage; 9-Aug-2016 at 1:19 PM. Reason: Enlarged lettering to make it easy to see for some
