Old 6-Aug-2016, 1:08 PM   #4
Jake V
The antenna you listed does not have good reputation.
If you're only interested in receiving the Chicago stations (and not Rockford), for a single antenna solution I'd try the Wineguard HD7698P pointed at 92 degrees (measured with a compass). You can also use a two antenna solution, like an Antennas Direct DB8e for UHF + Stellar Labs (30-2476) MCM Part #30-2476 for VHF HI.
Others will post.
