Old 6-Aug-2016, 1:13 AM   #16
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Originally Posted by newmguy View Post
I see you have two of these antennas. What other antennas are present in your system? Any UHF antennas combined?
What is the combiner you used?
What about splitters, amps, cable length?
I have my "south array" that points to Chicago with a 91XG 5 feet above the 30-2476 57' AGL. They are combined by an RCA PREAMP1. It is between the two antennas on both arrays.
The RG 6 is about 75' to the combiner. Alternatively, an additional 6 feet to back of the TV when hooked directly to the TV. I also have a network that distributes it through the house which adds a lot of legs to the system, which is mainly why I used the preamp I chose. Plus, that preamp is a combiner, kills two birds with one stone.
South Pointed Array:
My North pointing array is about 30' AGL and has an HDB91X above a 30-2476. They are also combined by an RCA PREAMP1. The RG-6 is about 45' to the indoor combiner, alternatively, an additional 6 feet to back of the TV when hooked directly to the TV. Sometimes I unhook the network and experiment with my TV in my man cave. That TV has 2 RF inputs.
North pointing array:
Both antennas are aimed correctly in the following pic. They both have rotators, which I found to be indispensable for aiming.
For size & height comparison:
File Type: jpg 2016-05-19 Antennas Finished 91XG & 30 2476 -20 resizes.jpg (135.8 KB, 3916 views)
