Try running a new report with an elevation estimate for a roof mount (as high as you can reasonably install at).
I suspect that a 4 bay panel (DB4, CM4221HD, etc) and a high-VHF (Y5713) will work well for you if outside in the clear. The VHF will have a broad beam-width as will the UHF antenna. Split the aim between the two station groups.
I'm hesitant to recommend an amplifier. I would try using a passive UVSJ to combine the signals into a single coax. http://www.solidsignal.com/pview.asp...Combiners&sku= A preamp can be added to the UHF antenna if it proves necessary.
