Old 3-Aug-2016, 9:57 PM   #9
athiktos
I think you should try it to satisfy your own curiosity; you will not be happy until you do.
Haha, well put.
A Channel Master 7778 or an RCA TVPRAMP1R.
The 7778 would require a UVSJ to combine the UHF and VHF antennas before the preamp.
The RCA is less expensive and has separate inputs for UHF and VHF antennas. But, it has some quality control problems including a history of problems with the separate/combined antenna switch. Sometimes the switch doesn't make good contact with the VHF antenna in the separate position. The fix is to combine the antennas with a UVSJ and connect to the combined input of the preamp.
Thank you very much. I will give this a try and let you know how it works.
athiktos is offline   Reply With Quote
