Thanks everyone for the suggestion. Let me find a pipe that will fit into the mast to extend it up another 5ft if possible per AdTech suggestion.
I'll also try the pre-amp per your suggestion rabbit73. Hopefully that helps a bit. and yes my tv has the signal strength indicator so that kind of help a bit but it's still a pain just because I have to go up and down the ladder to readjust it. I'll also find a Coax grounding box to help out with the static and perhaps find a way to ground the mast in case of lightning. I guess I need to find something to put in between so if lightning ever strike directly, at least my TV won't blow up.
tomfoolery, I angle the antenna up a bit like around 10 degree because I was hoping that it can avoid the tree in front a bit. Doesn't look like it's working.
Thanks everyone for all of your help. You are all very helpful and I really appreciate it.
