Old 25-Jan-2011, 1:20 AM   #9
tarq476
Thanks for the good recommendations. I am going to order the antenna, mast, and splitter and first attempt to use my current satellite mount. This would be easier and less intrusive, but the antenna will still be partly obstructed by the next house. I'm hoping I'll still get better reception than the indoor antenna, which is also blocked by the neighboring house.
If that doesn't work, I'll probably try to move up higher and use an eave mount like the CM-9030. Unfortunately I don't have a chimney, or I'd likely try that route.
tarq476 is offline   Reply With Quote
