If using a peak of the roof STRONG eave mount then the bottom antenna can be a foot or so on the mast pole above the peak of the roof and the top antenna can be at the top of the mast pole about 5 foot above the bottom antenna. And it is Ok for antennas to be mounted on different masts. It seams like some cash outlay at first , however think about it this way. What about that 100 dollar pay cable / pay satellite bill every month ?? When the antenna system is installed you are watching Free Digital Tv. And antennas last 5 / 10 years and longer. So with your case if you went all out and spent 500 dollars for the 2 antenna system then thats 14 cents a day through 10 years to pay for it. And if you went all out and installed a 1 antenna system how much would that be per day ?? And let's say that you found out about the thousands of movies and Tv shows with ROKU/NETFLIX for 10 dollars a month.
