If you are only feeding the antenna signal to one television then I'd remove the "8-Port Bi-Directional Cable TV HDTV Amplifier Splitter Signal Booster with Passive Return". Unless you are someday going to feed 8 televisions there is no need for it. Try feeding directly from the antenna directly to the one television to see what happens.
I'd also check to make sure the connections are good.
Questions:
1. Where is your antenna located? Attic? Roof? I see it's at 15 feet above the ground.
2. What direction is it aimed? Does it "look" into trees or buildings?
