Avoid making any holes in the roof. They almost always will lead to big problems down the road. The above linked installation instructions are good. My Dish Sat. was on the end of the ridge & I was able to use its mount to install my antenna. Also, used the cable from it. Saved a lot of time. The mast, or a piece of pipe, can be used, or be adapted to the Dish mount. I think you will be quite happy with your reception !
SAFETY is the biggest concern. Have a helper. Do not install when roof is wet or it is windy ! Keep antenna & ladders away from all power lines !!!!!
