Old 28-Jul-2016, 5:10 PM   #6
Would you suggest I get another antenna for a different angle outside of my DB4e and the VHF antenna aimed South?
No, I think the DB4e and the MCM VHF antenna aimed at about 181 degrees magnetic and combined with a UVSJ (not a splitter) would give you a good selection.
However, if another direction would give you a channel that is important to you, then you would need a third antenna and a switch or a separate tuner.
If you want to experiment with removing the reflector, that might be an interesting experiment. I don't see anything I would want from the north, but it might give you two CBSs.
