Old 25-Jul-2016, 9:03 PM   #3
rickbb
I would try removing the reflector from one of the DB4e's and aiming it slightly away from straight at the Indy channels. About SE or SSE is where I'd start.
With the reflector removed you will improve reception from the back of the array and by being slightly off from aiming directly at your main stations you can improve on reception from the sides.
If it doesn't work you can re-attach the reflector with sheet metal screws. Won't hurt the antenna at all.
