Old 18-Jul-2016, 11:23 PM   #3
You have some strong local FM transmitters in the same direction. I wonder if they might be causing interference to TV reception?
http://www.fmfool.com/modeling/tmp/8...f/Radar-FM.png
I added a Radio Shack RF interference filter too but no improvement.
Was it an FM filter, or something else?
Is the coax from the antenna grounded with a grounding block connected to the house electrical system ground?
he thinks it's probably trees
That certainly is possible if it is getting worse; trees do grow.
Given the mast height of a dish is only a couple of feet (although it's on a second story roof), would going up higher be our best bet?
It might help if there are trees in the signal path.
Any tall buildings in the signal path?
