Old 18-Jul-2016, 11:32 PM   #12
Thanks for the interesting report.
Without the wire mesh, the symbol rate was Zero. With the wire mesh it went to 100%.
WOW! Very impressive test; sounds promising.
Which way was the antenna aimed, and which side of the antenna for the mesh?
I'm trying to figure out if you were using a signal coming over the mountain from SSE or a signal from the east for reception.
I'm wondering how close the mesh can be to the antenna without detuning it.
I don't want the antenna to blow all the way to Kansas.
Ha Ha! Yes, you don't want to convert it into a kite.
Sounds like a compromise. Closer spacing of the rods or wires is more effective, but it increases the wind load.
