Old 18-Jul-2016, 6:54 PM   #1
ihwf_vp
Help with Reception - Hannibal, MO
Hello All-
I'm new to TV Fool and was looking for some help on a project. I live in Hannibal, MO which is 19 miles from transmitters in Quincy IL, and roughly 95 miles from transmitters in St Louis, MO. I can pick up the channels in Quincy with no problem and currently do on a small antenna at about 20 ft in height. I've been working on a project to try to pick up St Louis locals since that is the market in which I am originally from (and prefer).
For a little background, I have provided the link from the tv fool tool.. TV Fool. As far as my system, I am running a 1byone branded 100 mile range with power supply digital antenna.. Part number is OUS00-0549 from my roof about 25 ft off of the ground. I also have this plugged into a Radio Shack bi directional amplifier(item number 15-205) that I had laying around to try to overcome and cable loss I had.
I just installed this antenna on Saturday and right away I picked up 34 channels. I was able to receive in KTVI Channel 2, KMOV Channel 4, KSDK Channel 5, KETC Channel 9, KPLR Channel 11, KNLC Channel 24, and KDNL Channel 30.. Among other randoms. Those are the main stations though in St Louis. I'm not saying all 34 channels showed up with picture but it at least saw the channel and left a blank placeholder on a few of the lower powered ones. I initially watched channel 5 for about 5 minutes with no pixelation issues and then left the house. After I got back, only channel 4 would come in and nothing else. Later in the day, I got to where 4 was barely coming in as well. Since then, there has been good times where I've watched a few channels with no pixelation for a few minutes but for the most part, it is either not coming in, or pixelating too bad that its unwatchable.
I know that I am fighting some major distance and that is likely my main obstacle. I honestly didn't think that I would actually pick the channels up at all but now that I have at least seem them, its turned into a game for me to see if I can actually make it work. I've tried repointing but i'm perfectly set at 143 degrees. I've moved it some to 120 to 160 degrees just to see if it would make a difference but nothing yet. I've also messed with the elevation of the antenna a little.. Pointing it straight.. Pointing it with a slight angle up.. And a slight angle down. I've also tried a few other tvs in my house to rule out a crappy tuner but doesn't seem to be much of a difference from tv to tv. I've also had rainy days and clear days but hasn't really seemed to make much of a difference either.
If anyone has any tips or pointers to try, I'd love to hear. I'd be thrilled if I could make it work but I'm not holding my breath.
Thanks in advance.
ihwf_vp is offline   Reply With Quote
