Focusing only on the Orlando market...
The added height appears to provide significantly better signal levels. Still, If I were in that location, I'd have no qualms about using larger antennas such as the Winegard HD7698P
I realize that the stealth qualities of an antenna that size may be objectionable to some, but this location is far enough from the Orlando towers to require a mid to large size antenna mounted high enough to capture the modest amount of signal that's available.
(I'm delighted that your attic mounted antenna works well for you. I have to wonder if your location has significantly better reception conditions.)
