Old 10-Jul-2016, 7:46 PM   #1
SoHumble
Antenna and mounting advice
I have a neighbor that wants to cut the cord. This is his report
http://www.tvfool.com/?option=com_wr...e2cbb4e34247ed
I live just up the street from him and have an RCA ANT 751R that is mounted in the attic. I also had to add a a pre-amp when I split the signal to three tvs with one long run (about 100'). This arrangement works well for me.
His situation is a little different, in that he wants to mount the antenna outside. The plan is to mount a ANT 751R or Channel Master CM-3010HD Stealth antenna directly on the facia of his house so it will be as unobtrusive as possible.
The CM would probably be the least intrusive of the two. Do you think this set up will work? Also, the antenna cable will lead to the junction box currently connected to cable tv. So the antenna will use the cable already wired throughout his house.
Since the antenna will be outside, does the antenna need to be grounded? The cables are already grounded at the junction box.
Thanks
SoHumble is offline   Reply With Quote
