Have A 30db amp, question.
I mounted a Antennacraft® MXU59, high gain outdoor antenna above my roof and split off to two TVs. One TV has the 30db amp hooked up behind the screen and the other doesn't. The one with this amp works great of course the other doesn't but I switched connections at the 3-way splitter just to make sure - the splitter is fine and the other TV apparently needs a new amp as well.
Before I purchase the new amp, does anyone know if I can mount the amp right ahead of the 3-way splitter on the "in" side of the connections to "push" the amped signal instead of pull it from each TV?
If so that will at least save me some money and time on the project.
thanks
