Old 4-Jul-2016, 1:24 AM   #4
The link above in the first post ending in d52a is not using coordinates, it says block level.
WARNING: Address was only resolved to block level and might not be that close to your actual location. For more accurate results, try entering a specific address or coordinates.
Well, anyway, are you using a preamp?
Any trees in the signal path?
I will find out what antenna neighbor uses, it is about 6 feet long.
Good; where is it located, inside or outside?
