I wonder why the tuner seems like it's overloaded.
Could it be the higher gain on the antenna made this happen?
The tuner likely WAS overloaded. I don't know any specifics about the CM box, but certain older Tivo units, for example, had a built-in amplifier prior to its internal splitter.
It's likely that it's a combination of higher gain plus a different reception pattern.
ADTech you are a smart guy. Thanks a million for your help!!
Even a blind squirrel sometimes finds an acorn!
Happy to help out.
(to eliminate using a splitter)
Fell free to use a splitter post-amplification. You may need to further experiment with the location and amount of post-amplification attenuation to try and balance signal levels at the various tuners.
