Old 28-Jun-2016, 10:54 PM   #46
Pete Higgins
Pete Higgins's Avatar
HDB-8X Information
Sev,
Read through the following posts.
http://www.highdefforum.com/local-hd...own-brand.html
I’ve included a lot of test results from when I tried various combinations. I had an extra combiner so I ended up feeding the two panels from each HDB-8x into its supplied combiner and then the outputs of each antenna combiners into my extra combiner. I also tried feeding the cables from each 4-Bay section into a 4-Way splitter with very little difference.
These are heavy antennas (well built) so horizontal stacking (by the time you got proper spacing with a non-metallic support) would be problematic. Vertical stacking isn’t a problem.
